I tried using an Edit field with a Property that is set in a custom action, but get an error saying the edit field can only accept 512 characters (my results list is rather long).
I tried using a Text field associated with a Property as above, but there doesn't seem to be a way to add a scrollbar so the user can see all the text (once again, it's rather long)
It seems the best control would be a Scrollable Text control, but ISD7 wants you to statically link a rtf file (it fills in the Text property when compiled) and you can't associate the control with a Property (is this true?).
Does anybody know how I can show a long list of results to the user after the install? I don't want to use a ListBox because I want the user to be able to Copy/Paste the data if desired.
