Hi All,
I've posted this on the Installshield site, but not received any responses. Help would be appreciated as I am at a loss as to the cause of this problem!
Scenario: On a number (but not all) of my clients machines, when my Installshield package (Installshield 11) is uninstalled, mshtml.dll gets unregistered. This means that All folders in Windows Explorer appear empty, apart from a single grey rectangle icon in the top left hand corner. Internet explorer is also affected, with many pages no longer displaying images.
I tracked down the problem to mshtml.dll. If this file is registered again after uninstallation of my package, then the IE/Windows Explorer problem is corrected. (A repair of IE6 also fixes the problem)
I cannot track the cause of this problem down. I have logged the uninstall and install and cannot see any issue. This problem did not happen before I upgraded from Developer 7 to Premier 11.
Please see below for the log file of an uninstall on an affected machine.
Andrew
=== Verbose logging started: 06/12/2005 10:44:15 Build type: SHIP UNICODE 2.00.2600.1183 Calling process: C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\11\INTEL3~1\IDriver.exe ===
=== Logging started: 06/12/2005 10:44:15 ===
Action start 10:44:16: ISVerifyScriptingRuntime.
Action ended 10:44:16: ISVerifyScriptingRuntime. Return value 1.
Action start 10:44:16: ISSetupFilesExtract.
1: Starting to extract setup files
1: Getting SUPPORTDIR property :
1: Extracting SetupFiles to: D:\Profiles\mstrat\LOCALS~1\Temp\{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}
1: Getting ISSetupFile table view
1: Executing ISSetupFile table view
1: Extracting Setup File:
1: D:\Profiles\mstrat\LOCALS~1\Temp\{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}\@bcSplash6.bmp
1: Setting SUPPORTDIR property to: D:\Profiles\mstrat\LOCALS~1\Temp\{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}
1: Setting ISSETUPFILESCOMPLETED property
Action ended 10:44:16: ISSetupFilesExtract. Return value 1.
Action start 10:44:16: AppSearch.
Action 10:44:16: AppSearch. Searching for installed applications
AppSearch: Property: MSXML_FOUND.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3, Signature: MSXML3DLL.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3
AppSearch: Property: OLDER_MSXML_FOUND.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3, Signature: MSXML3DLL_OLDER.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3
AppSearch: Property: MSXML_FOUND.B560EED0_07AE_45A2_BDB9_BED4D4DA518C, Signature: MSXML3DLL.B560EED0_07AE_45A2_BDB9_BED4D4DA518C
AppSearch: Property: OLDER_MSXML_FOUND.B560EED0_07AE_45A2_BDB9_BED4D4DA518C, Signature: MSXML3DLL_OLDER.B560EED0_07AE_45A2_BDB9_BED4D4DA518C
Action ended 10:44:16: AppSearch. Return value 1.
Action start 10:44:16: LaunchConditions.
Action ended 10:44:16: LaunchConditions. Return value 1.
Action start 10:44:16: FindRelatedProducts.
Action ended 10:44:16: FindRelatedProducts. Return value 0.
Action start 10:44:16: ValidateProductID.
Action ended 10:44:16: ValidateProductID. Return value 1.
Action start 10:44:16: CostInitialize.
Action ended 10:44:16: CostInitialize. Return value 1.
Action start 10:44:16: FileCost.
Action ended 10:44:16: FileCost. Return value 1.
Action start 10:44:16: IsolateComponents.
Action ended 10:44:16: IsolateComponents. Return value 1.
Action start 10:44:16: CostFinalize.
Action ended 10:44:16: CostFinalize. Return value 1.
Action start 10:44:16: SetARPReadme.
Action ended 10:44:16: SetARPReadme. Return value 1.
Action start 10:44:16: MigrateFeatureStates.
Action ended 10:44:16: MigrateFeatureStates. Return value 0.
Action start 10:44:16: ISSetupFilesCleanup.
1: Standard project type, let scripting engine clean up setup files...skipping action
Action ended 10:44:16: ISSetupFilesCleanup. Return value 1.
1: Could not find setup.ini where expected (C:\WINNT\Downloaded Installations\{43A6DE89-FF41-48CF-ABDC-7BB7EA42BD85}\). Defaulting to skin file setup.skn
1: Not using skins for this installation. Could not find skin file C:\WINNT\Downloaded Installations\{43A6DE89-FF41-48CF-ABDC-7BB7EA42BD85}\setup.isn.
1: Ready to launch __OnMsiMaintenance.
1: Ready to launch MsiInstallProduct, Command line : REMOVE=All ALLUSERS=1 ALLUSERSPROFILE=C:\ ARPCOMMENTS="Use the following to get technical support for @bc." ARPCONTACT="IS Express/Helpdesk" ARPHELPLINK=http://zwcwy0jf/@bc ARPHELPTELEPHONE="IS Helpdesk" ARPNOMODIFY=1 ARPNOREPAIR=1 ARPREADME=ReadMe ARPURLINFOABOUT=http://zwcwy0jf/@bc ARPURLUPDATEINFO=http://zwcwy0jf/@bc COMPANYNAME="NORTEL NETWORKS" DWUSINTERVAL=30 DWUSLINK=CE9C808F2E7C974889AC50E8DEEC978FBEBBF08FFEECD0EFCE9B90BFF9FB2098F9FC27E8FEAC INSTALLDIR="C:\Program Files\@bc\" INSTALLLEVEL=1 ISSCRIPT_ENGINE_VERSION=11.0.0.28844 ISSCRIPT_VERSION_MISSING="The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance." ISSCRIPT_VERSION_OLD="The InstallScript engine on this machine is older than the version required to run this setup. If available, please install the latest version of ISScript.msi, or contact your support personnel for further assistance." ISSETUPDRIVEN=1 ISSETUPFILESCOMPLETED=Completed ISSETUP_UISEQUENCE_PROCESSED=1 ISVROOT_PORT_NO=0 IS_COMPLUS_PROGRESSTEXT_COST="Costing COM+ application: [1]" IS_COMPLUS_PROGRESSTEXT_INSTALL="Installing COM+ application: [1]" IS_COMPLUS_PROGRESSTEXT_UNINSTALL="Uninstalling COM+ application: [1]" IS_PROGMSG_XML_COSTING="Costing XML files..." IS_PROGMSG_XML_CREATE_FILE="Creating XML file %s..." IS_PROGMSG_XML_FILES="Performing XML file changes..." IS_PROGMSG_XML_REMOVE_FILE="Removing XML file %s..." IS_PROGMSG_XML_ROLLBACK_FILES="Rolling back XML file changes..." IS_PROGMSG_XML_UPDATE_FILE="Updating XML file %s..." IS_SQLSERVER_AUTHENTICATION=0 IS_SQLSERVER_USERNAME=sa MS.1E64E430_36E0_11D2_A794_0060089A724B=C:\WINNT\system32\ MS.3207D1B0_80E5_11D2_B95D_006097C4DE24=C:\WINNT\system32\ MS.3207D1B6_80E5_11D2_B95D_006097C4DE24=C:\WINNT\system32\ MS.3207D1B9_80E5_11D2_B95D_006097C4DE24=C:\WINNT\system32\ MS.51D569E0_8A28_11D2_B962_006097C4DE24=C:\WINNT\system32\ MS.51D569E3_8A28_11D2_B962_006097C4DE24=C:\WINNT\system32\ MS.576D64B0_7413_11D2_B954_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD1C_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD21_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD23_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD26_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD27_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD29_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD3D_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD45_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.7EBEDD46_AA66_11D2_B980_006097C4DE24=C:\WINNT\system32\ MS.8C0C59A0_7DC8_11D2_B95D_006097C4DE24=C:\WINNT\system32\ MSXML_FOUND.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3=C:\WINNT\system32\msxml3.dll MSXML_FOUND.B560EED0_07AE_45A2_BDB9_BED4D4DA518C=C:\WINNT\system32\msxml3.dll MY_="D:\Profiles\mstrat\My Documents\My \" MY__BC_CPM_FILES="D:\Profiles\mstrat\My Documents\My @bc CPM Files\" MY__BC_CPM_UPLOAD_FILES="D:\Profiles\mstrat\My Documents\My @bc CPM Upload Files\" MY__BC_PAQS_UPLOAD_FILES="D:\Profiles\mstrat\My Documents\My @bc PAQS Upload Files\" MY__BC_PAQS_UPLOAD_FILES1="D:\Profiles\mstrat\My Documents\My @bc PAQS Upload Files\" MY__BC_PAQS_UPLOAD_FILES2="D:\Profiles\mstrat\My Documents\My @bc PAQS Upload Files\" MY__BC_SPO_VARIABLES="D:\Profiles\mstrat\My Documents\My @bc SPO Variables\" MY__BC_SPO_VARIABLES1="C:\My @bc SPO Variables\" MY__BC_SPO_VARIABLES2="D:\Profiles\mstrat\My Documents\My @bc SPO Variables\" MY__BC_SPO_VARIABLES3="D:\Profiles\mstrat\My Documents\My @bc SPO Variables\" PRODUCTLANGUAGE=1033 PROGMSG_IIS_CREATEAPPPOOL="Creating application pool %s" PROGMSG_IIS_CREATEAPPPOOLS="Creating application Pools..." PROGMSG_IIS_CREATEVROOT="Creating IIS virtual directory %s" PROGMSG_IIS_CREATEVROOTS="Creating IIS virtual directories..." PROGMSG_IIS_CREATEWEBSERVICEEXTENSION="Creating web service extension" PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS="Creating web service extensions..." PROGMSG_IIS_EXTRACT="Extracting information for IIS virtual directories..." PROGMSG_IIS_EXTRACTDONE="Extracted information for IIS virtual directories..." PROGMSG_IIS_REMOVEAPPPOOL="Removing application pool" PROGMSG_IIS_REMOVEAPPPOOLS="Removing application pools..." PROGMSG_IIS_REMOVESITE="Removing web site at port %d" PROGMSG_IIS_REMOVEVROOT="Removing IIS virtual directory %s" PROGMSG_IIS_REMOVEVROOTS="Removing IIS virtual directories..." PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION="Removing web service extension" PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS="Removing web service extensions..." PROGMSG_IIS_ROLLBACKAPPPOOLS="Rolling back application pools..." PROGMSG_IIS_ROLLBACKVROOTS="Rolling back virtual directory and web site changes..." PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS="Rolling back web service extensions..." REBOOT=Suppress ROOTDRIVE=C:\ SETUPEXEDIR=D:\Profiles\mstrat\Desktop STANDARD_USE_SETUPEXE="This installation can not be run by directly launching the MSI package; you must run setup.exe." SUPPORTDIR=D:\Profiles\mstrat\LOCALS~1\Temp\{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF} TARGETDIR=C:\ TEMPLATES="C:\Program Files\@bc\Templates\" USERNAME=nortel USERPROFILE=C:\ _BC="C:\Program Files\@bc\" ARPSYSTEMCOMPONENT=1 ARPNOMODIFY=1 ARPNOREMOVE=1 ISSETUPDRIVEN=1
=== Verbose logging stopped: 06/12/2005 10:44:24 ===
=== Verbose logging started: 06/12/2005 10:44:24 Build type: SHIP UNICODE 2.00.2600.1183 Calling process: C:\PROGRA~1\COMMON~1\INSTAL~1\Driver\11\INTEL3~1\IDriver.exe ===
MSI © (84:24): Resetting cached policy values
MSI © (84:24): Machine policy value 'Debug' is 0
MSI © (84:24): ******* RunEngine:
******* Product: {BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}
******* Action:
******* CommandLine: **********
MSI © (84:24): Client-side and UI is none or basic: Running entire install on the server.
MSI © (84:24): Grabbed execution mutex.
MSI © (84:24): Cloaking enabled.
MSI © (84:24): Incrementing counter to disable shutdown. Counter after increment: 0
*** Log Line Missing ***
MSI (s) (00:A8): Resetting cached policy values
MSI (s) (00:A8): Machine policy value 'Debug' is 0
MSI (s) (00:A8): ******* RunEngine:
******* Action:
MSI (s) (00:A8): Machine policy value 'DisableUserInstalls' is 0
MSI (s) (00:A8): Setting cached product context: machine assigned for product: F0AD0AABF54455C49900E09C1DC5FCFC
MSI (s) (00:A8): Using cached product context: machine assigned for product: F0AD0AABF54455C49900E09C1DC5FCFC
MSI (s) (00:A8): End dialog not enabled
MSI (s) (00:A8): Original package ==> C:\WINNT\Installer\2f14a3.msi
MSI (s) (00:A8): Package we're running from ==> C:\WINNT\Installer\2f14a3.msi
MSI (s) (00:A8): APPCOMPAT: looking for appcompat database entry with ProductCode '{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}'.
MSI (s) (00:A8): APPCOMPAT: no matching ProductCode found in database.
MSI (s) (00:A8): Transforms are not secure.
MSI (s) (00:A8): Note: 1: 2262 2: Control 3: -2147287038
MSI (s) (00:A8): Command Line: REMOVE=All ALLUSERS=1 ALLUSERSPROFILE=C:\ ARPCOMMENTS=Use the following to get technical support for @bc. ARPCONTACT=IS Express/Helpdesk ARPHELPLINK=http://zwcwy0jf/@bc ARPHELPTELEPHONE=IS Helpdesk ARPNOMODIFY=1 ARPNOREPAIR=
1 ARPREADME=ReadMe ARPURLINFOABOUT=http://zwcwy0jf/@bc ARPURLUPDATEINFO=http://zwcwy0jf/@bc COMPANYNAME=NORTEL NETWORKS DWUSINTERVAL=30 DWUSLINK=CE9C808F2E7C974889AC50E8DEEC978FBEBBF08FFEECD0EFCE9B90BFF9FB2098F9FC27E8FEAC INSTALLDIR=C:\Program Files\@bc\
INSTALLLEVEL=1 ISSCRIPT_ENGINE_VERSION=11.0.0.28844 ISSCRIPT_VERSION_MISSING=The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance. ISSCRIPT_VERSION_OLD=The
InstallScript engine on this machine is older than the version required to run this setup. If available, please install the latest version of ISScript.msi, or contact your support personnel for further assistance. ISSETUPDRIVEN=1 ISSETUPFILESCOMPLETED=Co
MSI (s) (00:A8): Product Code passed to Engine.Initialize: '{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}'
MSI (s) (00:A8): Product Code from property table before transforms: '{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}'
MSI (s) (00:A8): Product Code from property table after transforms: '{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}'
MSI (s) (00:A8): Product registered: entering maintenance mode
MSI (s) (00:A8): Package name retrieved from configuration data: '@bc.msi'
MSI (s) (00:A8): Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI (s) (00:A8): Note: 1: 2729
MSI (s) (00:A8): Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (00:A8): Machine policy value 'DisableMsi' is 0
MSI (s) (00:A8): Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:A8): User policy value 'AlwaysInstallElevated' is 0
MSI (s) (00:A8): Product {BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF} is admin assigned: LocalSystem owns the publish key.
MSI (s) (00:A8): Product {BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF} is managed.
MSI (s) (00:A8): Running product '{BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}' with elevated privileges: Product is assigned.
MSI (s) (00:A8): TRANSFORMS property is now:
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Application Data
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Favorites
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\NetHood
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\My Documents
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\PrintHood
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Recent
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\SendTo
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Templates
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\All Users\Application Data
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Local Settings\Application Data
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\My Documents\My Pictures
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\All Users\Start Menu\Programs\Administrative Tools
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\All Users\Start Menu\Programs\Startup
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\All Users\Desktop
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Start Menu\Programs\Administrative Tools
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Start Menu\Programs\Startup
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\mstrat\Desktop
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: D:\Profiles\All Users\Templates
MSI (s) (00:A8): SHELL32::SHGetFolderPath returned: C:\WINNT\Fonts
MSI (s) (00:A8): Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (00:A8): MSCOREE not loaded loading copy from system32
=== Logging started: 06/12/2005 10:44:24 ===
MSI (s) (00:A8): Machine policy value 'DisableRollback' is 0
MSI (s) (00:A8): User policy value 'DisableRollback' is 0
MSI (s) (00:A8): Doing action: INSTALL
Action start 10:44:24: INSTALL.
MSI (s) (00:A8): Running ExecuteSequence
MSI (s) (00:A8): Doing action: ISMsiServerStartup
Action start 10:44:24: ISMsiServerStartup.
MSI (s) (00:A8): Creating MSIHANDLE (1) of type 790542 for thread 2728
Action ended 10:44:25: ISMsiServerStartup. Return value 1.
MSI (s) (00:A8): Doing action: ISStartup
Action start 10:44:25: ISStartup.
MSI (s) (00:A8): Creating MSIHANDLE (2) of type 790542 for thread 2728
1: The InstallScript engine version currently installed on this machine is adequate.
1: Event 'E442597' is created
1: Ev1483736
Action ended 10:44:25: ISStartup. Return value 1.
MSI (s) (00:A8): Doing action: ISRollbackCleanup
Action start 10:44:25: ISRollbackCleanup.
MSI (s) (00:A8): Creating MSIHANDLE (6) of type 790542 for thread 2728
Action ended 10:44:25: ISRollbackCleanup. Return value 1.
MSI (s) (00:A8): Skipping action: OnCheckSilentInstall (condition is false)
MSI (s) (00:A8): Doing action: ISSetupFilesExtract
Action start 10:44:25: ISSetupFilesExtract.
MSI (s) (00:A8): Creating MSIHANDLE (7) of type 790542 for thread 2728
1: SetupFile Extraction has been run previously...skipping action
Action ended 10:44:25: ISSetupFilesExtract. Return value 1.
MSI (s) (00:A8): Doing action: AppSearch
Action start 10:44:25: AppSearch.
Action 10:44:25: AppSearch. Searching for installed applications
MSI (s) (00:A8): Note: 1: 2262 2: CompLocator 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: IniLocator 3: -2147287038
Action ended 10:44:26: AppSearch. Return value 1.
MSI (s) (00:A8): Doing action: LaunchConditions
Action start 10:44:26: LaunchConditions.
MSI (s) (00:A8): Note: 1: 2262 2: LaunchCondition 3: -2147287038
Action ended 10:44:26: LaunchConditions. Return value 1.
MSI (s) (00:A8): Skipping action: FindRelatedProducts (condition is false)
MSI (s) (00:A8): Skipping action: CCPSearch (condition is false)
MSI (s) (00:A8): Skipping action: RMCCPSearch (condition is false)
MSI (s) (00:A8): Doing action: ValidateProductID
Action start 10:44:26: ValidateProductID.
Action ended 10:44:26: ValidateProductID. Return value 1.
MSI (s) (00:A8): Doing action: setUserProfileNT
Action start 10:44:26: setUserProfileNT.
Action ended 10:44:26: setUserProfileNT. Return value 1.
MSI (s) (00:A8): Skipping action: SetAllUsersProfileNT (condition is false)
MSI (s) (00:A8): Doing action: setAllUsersProfile2K
Action start 10:44:26: setAllUsersProfile2K.
Action ended 10:44:26: setAllUsersProfile2K. Return value 1.
MSI (s) (00:A8): Doing action: CostInitialize
Action start 10:44:26: CostInitialize.
Action ended 10:44:26: CostInitialize. Return value 1.
MSI (s) (00:A8): Doing action: WdSfpCaCacheDir.41646F16_4E6C_4E96_BF1B_772105414B9D
Action start 10:44:26: WdSfpCaCacheDir.41646F16_4E6C_4E96_BF1B_772105414B9D.
Action ended 10:44:26: WdSfpCaCacheDir.41646F16_4E6C_4E96_BF1B_772105414B9D. Return value 1.
MSI (s) (00:A8): Doing action: FileCost
Action start 10:44:26: FileCost.
MSI (s) (00:A8): Note: 1: 2262 2: MsiAssembly 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: IniFile 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: MoveFile 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: ReserveCost 3: -2147287038
Action ended 10:44:26: FileCost. Return value 1.
MSI (s) (00:A8): Doing action: IsolateComponents
Action start 10:44:26: IsolateComponents.
MSI (s) (00:A8): Note: 1: 2262 2: IsolatedComponent 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: BindImage 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (00:A8): Note: 1: 2235 2: 3: StreamRef_ 4: SELECT `File_`,`Sequence`,`PatchSize`,`Attributes`, NULL, `StreamRef_` FROM `Patch` WHERE File_ = ?
Action ended 10:44:26: IsolateComponents. Return value 1.
MSI (s) (00:A8): Skipping action: CDirSystemSFPCacheDir.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3 (condition is false)
MSI (s) (00:A8): Skipping action: CDirSystemSFPCacheDir.B560EED0_07AE_45A2_BDB9_BED4D4DA518C (condition is false)
MSI (s) (00:A8): Doing action: CostFinalize
Action start 10:44:26: CostFinalize.
MSI (s) (00:A8): Note: 1: 2262 2: Condition 3: -2147287038
MSI (s) (00:A8): Target path resolution complete. Dumping Directory table...
MSI (s) (00:A8): Note: target paths subject to change (via custom actions or browsing)
MSI (s) (00:A8): Dir (target): Key: TARGETDIR , Object: C:\
MSI (s) (00:A8): Dir (target): Key: WindowsVolume , Object: C:\
MSI (s) (00:A8): Dir (target): Key: WindowsFolder , Object: C:\WINNT\
MSI (s) (00:A8): Dir (target): Key: USERPROFILE , Object: D:\Profiles\mstrat\
MSI (s) (00:A8): Dir (target): Key: TemplateFolder , Object: D:\Profiles\All Users\Templates\
MSI (s) (00:A8): Dir (target): Key: TempFolder , Object: D:\Profiles\mstrat\LOCALS~1\Temp\
MSI (s) (00:A8): Dir (target): Key: SystemFolder , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: CDirSystemSFPCacheDir.B560EED0_07AE_45A2_BDB9_BED4D4DA518C , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD46_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD46_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD46_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD45_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD45_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD45_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: CDirSystemSFPCacheDir.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.51D569E3_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.51D569E3_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.51D569E3_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.1E64E430_36E0_11D2_A794_0060089A724B , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.1E64E430_36E0_11D2_A794_0060089A724B , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.1E64E430_36E0_11D2_A794_0060089A724B , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD3D_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD3D_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD3D_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD29_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD29_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD29_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD27_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD27_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD27_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD26_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD26_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD26_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD23_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD23_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD23_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD21_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD21_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD21_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.3207D1B9_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.3207D1B9_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.3207D1B9_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.3207D1B6_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.3207D1B6_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.3207D1B6_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.7EBEDD1C_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.7EBEDD1C_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.7EBEDD1C_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.576D64B0_7413_11D2_B954_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.576D64B0_7413_11D2_B954_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.576D64B0_7413_11D2_B954_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: Redist.3207D1B0_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: MS.3207D1B0_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System.3207D1B0_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\system32\
MSI (s) (00:A8): Dir (target): Key: System64Folder , Object: C:\
MSI (s) (00:A8): Dir (target): Key: System16Folder , Object: C:\WINNT\system\
MSI (s) (00:A8): Dir (target): Key: StartupFolder , Object: D:\Profiles\All Users\Start Menu\Programs\Startup\
MSI (s) (00:A8): Dir (target): Key: StartMenuFolder , Object: D:\Profiles\All Users\Start Menu\
MSI (s) (00:A8): Dir (target): Key: SendToFolder , Object: D:\Profiles\mstrat\SendTo\
MSI (s) (00:A8): Dir (target): Key: ProgramMenuFolder , Object: D:\Profiles\All Users\Start Menu\Programs\
MSI (s) (00:A8): Dir (target): Key: new_folder1 , Object: D:\Profiles\All Users\Start Menu\Programs\@bc\
MSI (s) (00:A8): Dir (target): Key: ProgramFiles64Folder , Object: C:\
MSI (s) (00:A8): Dir (target): Key: PrimaryVolumePath , Object: C:\
MSI (s) (00:A8): Dir (target): Key: MyPicturesFolder , Object: D:\Profiles\mstrat\My Documents\My Pictures\
MSI (s) (00:A8): Dir (target): Key: MY__BC_SPO_VARIABLES1 , Object: C:\My @bc SPO Variables\
MSI (s) (00:A8): Dir (target): Key: PersonalFolder , Object: D:\Profiles\mstrat\My Documents\
MSI (s) (00:A8): Dir (target): Key: MY__BC_SPO_VARIABLES3 , Object: D:\Profiles\mstrat\My Documents\My @bc SPO Variables\
MSI (s) (00:A8): Dir (target): Key: MY__BC_SPO_VARIABLES2 , Object: D:\Profiles\mstrat\My Documents\My @bc SPO Variables\
MSI (s) (00:A8): Dir (target): Key: MY__BC_SPO_VARIABLES , Object: D:\Profiles\mstrat\My Documents\My @bc SPO Variables\
MSI (s) (00:A8): Dir (target): Key: MY__BC_PAQS_UPLOAD_FILES2 , Object: D:\Profiles\mstrat\My Documents\My @bc PAQS Upload Files\
MSI (s) (00:A8): Dir (target): Key: MY__BC_PAQS_UPLOAD_FILES1 , Object: D:\Profiles\mstrat\My Documents\My @bc PAQS Upload Files\
MSI (s) (00:A8): Dir (target): Key: MY__BC_PAQS_UPLOAD_FILES , Object: D:\Profiles\mstrat\My Documents\My @bc PAQS Upload Files\
MSI (s) (00:A8): Dir (target): Key: MY__BC_CPM_UPLOAD_FILES , Object: D:\Profiles\mstrat\My Documents\My @bc CPM Upload Files\
MSI (s) (00:A8): Dir (target): Key: MY__BC_CPM_FILES , Object: D:\Profiles\mstrat\My Documents\My @bc CPM Files\
MSI (s) (00:A8): Dir (target): Key: MY_ , Object: D:\Profiles\mstrat\My Documents\My\
MSI (s) (00:A8): Dir (target): Key: LocalAppDataFolder , Object: D:\Profiles\mstrat\Local Settings\Application Data\
MSI (s) (00:A8): Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files\
MSI (s) (00:A8): Dir (target): Key: ISYourCompanyDir , Object: C:\Program Files\Your Company Name\
MSI (s) (00:A8): Dir (target): Key: ISYourProductDir , Object: C:\Program Files\Your Company Name\Your Product Name\
MSI (s) (00:A8): Dir (target): Key: _BC , Object: C:\Program Files\@bc\
MSI (s) (00:A8): Dir (target): Key: INSTALLDIR , Object: C:\Program Files\@bc\
MSI (s) (00:A8): Dir (target): Key: TEMPLATES , Object: C:\Program Files\@bc\Templates\
MSI (s) (00:A8): Dir (target): Key: GlobalAssemblyCache , Object: C:\
MSI (s) (00:A8): Dir (target): Key: FontsFolder , Object: C:\WINNT\Fonts\
MSI (s) (00:A8): Dir (target): Key: FavoritesFolder , Object: D:\Profiles\mstrat\Favorites\
MSI (s) (00:A8): Dir (target): Key: DesktopFolder , Object: D:\Profiles\All Users\Desktop\
MSI (s) (00:A8): Dir (target): Key: CommonFilesFolder , Object: C:\Program Files\Common Files\
MSI (s) (00:A8): Dir (target): Key: CommonFiles64Folder , Object: C:\
MSI (s) (00:A8): Dir (target): Key: CommonAppDataFolder , Object: D:\Profiles\All Users\Application Data\
MSI (s) (00:A8): Dir (target): Key: AppDataFolder , Object: D:\Profiles\mstrat\Application Data\
MSI (s) (00:A8): Dir (target): Key: AdminToolsFolder , Object: D:\Profiles\All Users\Start Menu\Programs\Administrative Tools\
MSI (s) (00:A8): Dir (target): Key: ALLUSERSPROFILE , Object: D:\Profiles\All Users\
MSI (s) (00:A8): Disallowing uninstallation of component: {FC3E0B6A-F62B-11D1-B144-00C04F990B2B} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {397D101E-A762-11D2-B97E-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {997FA962-E067-11D1-9396-00A0C90F27F9} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {474F61F1-7342-11D2-A199-00A0C90AB50F} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {10048713-2C96-11D2-9A97-006097C4E452} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {1CA051B0-1B70-11D2-9ADD-006097C4E452} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {1CA051B6-1B70-11D2-9ADD-006097C4E452} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {BF4D7A70-D89D-11D1-A17D-00A0C90AB50F} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {1D2B754A-CD9A-11D1-8279-00C04FC21633} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {397D1016-A762-11D2-B97E-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {996512A7-AA46-11D2-B97F-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {A8A1495F-36E5-11D2-B15A-00C04F990B2B} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {996512A5-AA46-11D2-B97F-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {996512A3-AA46-11D2-B97F-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {22056900-C842-11D1-A0DD-00A0C9054277} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {3207D1B8-80E5-11D2-B95D-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {996512A1-AA46-11D2-B97F-006097C4DE24} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {FC3E0B6E-F62B-11D1-B144-00C04F990B2B} since another client exists
MSI (s) (00:A8): Disallowing uninstallation of component: {3207D1B1-80E5-11D2-B95D-006097C4DE24} since another client exists
Action ended 10:44:26: CostFinalize. Return value 1.
MSI (s) (00:A8): Doing action: MSXMLInfInstall.B560EED0_07AE_45A2_BDB9_BED4D4DA518C
Action start 10:44:26: MSXMLInfInstall.B560EED0_07AE_45A2_BDB9_BED4D4DA518C.
Action ended 10:44:26: MSXMLInfInstall.B560EED0_07AE_45A2_BDB9_BED4D4DA518C. Return value 1.
MSI (s) (00:A8): Doing action: MSXMLDllInstall.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3
Action start 10:44:26: MSXMLDllInstall.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3.
Action ended 10:44:26: MSXMLDllInstall.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3. Return value 1.
MSI (s) (00:A8): Doing action: SetARPReadme
Action start 10:44:26: SetARPReadme.
Action ended 10:44:26: SetARPReadme. Return value 1.
MSI (s) (00:A8): Doing action: SetODBCFolders
Action start 10:44:26: SetODBCFolders.
MSI (s) (00:A8): Note: 1: 2262 2: ODBCDriver 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: ODBCTranslator 3: -2147287038
Action ended 10:44:26: SetODBCFolders. Return value 1.
MSI (s) (00:A8): Doing action: MigrateFeatureStates
Action start 10:44:26: MigrateFeatureStates.
MSI (s) (00:A8): Skipping MigrateFeatureStates action: not run in maintenance mode
Action ended 10:44:26: MigrateFeatureStates. Return value 0.
MSI (s) (00:A8): Doing action: InstallValidate
Action start 10:44:26: InstallValidate.
MSI (s) (00:A8): Feature: abc; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Feature: Documentation; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Feature: DummyFeature; Installed: Null; Request: Null; Action: Null
MSI (s) (00:A8): Component: Database; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: XMLTemplate; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: abcMain; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: ExCooltips; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: RICHTX32; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: WRMenu; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: admin; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Contacts; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Core; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: InBase; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: ISM; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Lines; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Login; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Misc; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: OEM; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Results; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Summary; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Traffic; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Trunks; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: More; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Products; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: BBnSTP; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: BBnSTPSoftware; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: BBnSTPadmin; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: CentrexIP; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Frames; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Remotes; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: CS2Ksw; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: EM; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: MG3500; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: PP8600; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Contivity; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: adminSucc; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: _632TXE; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: CCF_Picture; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: OAME_Picture; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: IMS; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: InBaseSucc; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: PP8600co; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: SAMF_Picture; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: PVG; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: AllOtherFiles; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: ChgNotes; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: ScriptingRuntime; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: DBAdmin; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: TDMsw; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: CS2KcSummary; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: MG9000; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: LivelinkCOMObject; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: SPO; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: SPORemotes; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: SPOServices; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Common; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Details; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Livelink; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: LAPIdlls; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: BCPMAS; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: _8608SXE; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: _8648TXE; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: abcUserGuide; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: PVG7K; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: SolverSpreadSheets; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Mediant_2000; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: MBScroll; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: COAM_Picture; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: BASG; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: SuccessionTraffic; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: MCSInputMap; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: XPSP2RegFix; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Ethersets; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Nuera; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: UMUX1500; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: ACME; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: CallServerCore; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: AllOtherFiles3; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: AllOtherFiles2; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: AllOtherFiles1; Installed: Local; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: Global_Controls_COMCATDLL.3207D1B0_80E5_11D2_B95D_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_Comdlg32ocx.576D64B0_7413_11D2_B954_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSBINDDLL.7EBEDD1C_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSCOMCT2OCX.3207D1B6_80E5_11D2_B95D_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSCOMCTLOCX.3207D1B9_80E5_11D2_B95D_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSDATLSTOCX.7EBEDD21_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSDBRPTRDLL.7EBEDD23_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSFlexGridOCX.7EBEDD26_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSHFLXGDOCX.7EBEDD27_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_MSINETOCX.7EBEDD29_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Vba_VBStandardFormat.7EBEDD3D_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Vba_VbRuntime.1E64E430_36E0_11D2_A794_0060089A724B; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_VC_CPPRT60.51D569E3_8A28_11D2_B962_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_VC_CRT.51D569E0_8A28_11D2_B962_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: MSXML3_msxml3.dll.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: MSXML3_msxml3r.dll.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: MSXML3_msxml3a.dll.7E4F6CB4_E769_4917_AA7E_0E3CA074ABB3; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_System_OLEPRO32.8C0C59A0_7DC8_11D2_B95D_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_System_STDOLE.8C0C59A0_7DC8_11D2_B95D_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_System_OLEAUT32.8C0C59A0_7DC8_11D2_B95D_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_SYSINFOOCX.7EBEDD45_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: Global_Controls_Tabctl32ocx.7EBEDD46_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: MSXML3_INF_msxmlx.cat.B560EED0_07AE_45A2_BDB9_BED4D4DA518C; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: MSXML3_INF_msxmlx.inf.B560EED0_07AE_45A2_BDB9_BED4D4DA518C; Installed: Local; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __ChgNotes65; Installed: Null; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: __abcUserGuide65; Installed: Null; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: __Database65; Installed: Null; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: __Login65; Installed: Null; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: __Global_Controls_COMCATDLL.3207D1B0_80E5_65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_Comdlg32ocx.576D64B0_74165; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSBINDDLL.7EBEDD1C_AA66_65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSCOMCT2OCX.3207D1B6_80E65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSCOMCTLOCX.3207D1B9_80E65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSDATLSTOCX.7EBEDD21_AA665; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSDBRPTRDLL.7EBEDD23_AA665; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSFlexGridOCX.7EBEDD26_A65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSHFLXGDOCX.7EBEDD27_AA665; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_MSINETOCX.7EBEDD29_AA66_65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Vba_VBStandardFormat.7EBEDD3D_AA665; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Vba_VbRuntime.1E64E430_36E0_11D2_65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_System_STDOLE.8C0C59A0_7DC8_11D2_65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_System_OLEAUT32.8C0C59A0_7DC8_11D65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_SYSINFOOCX.7EBEDD45_AA6665; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __Global_Controls_Tabctl32ocx.7EBEDD46_AA665; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: __XPSP2RegFix65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Component: ___632TXE65; Installed: Null; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: __RICHTX3265; Installed: Null; Request: Absent; Action: Absent
MSI (s) (00:A8): Component: __ScriptingRuntime65; Installed: Null; Request: Absent; Action: Null
MSI (s) (00:A8): Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: SelfReg 3: -2147287038
MSI (s) (00:A8): Note: 1: 2262 2: Font 3: -2147287038
MSI (s) (00:A8): Note: 1: 1306 2: C:\Program Files\@bc\Templates\SuccessionCI.dot
MSI (s) (00:A8): Note: 1: 1306 2: C:\Program Files\@bc\Templates\CI.dot
MSI (s) (00:A8): Note: 1: 2727 2:
Action ended 10:44:51: InstallValidate. Return value 1.
MSI (s) (00:A8): Doing action: RemoveExistingProducts
Action start 10:44:51: RemoveExistingProducts.
MSI (s) (00:A8): Skipping RemoveExistingProducts action: current configuration is maintenance mode or an uninstall
Action ended 10:44:51: RemoveExistingProducts. Return value 0.
MSI (s) (00:A8): Doing action: OnGeneratingMSIScript
Action start 10:44:51: OnGeneratingMSIScript.
MSI (s) (00:A8): Creating MSIHANDLE (10) of type 790542 for thread 2728
Action ended 10:44:51: OnGeneratingMSIScript. Return value 1.
MSI (s) (00:A8): Doing action: InstallInitialize
Action start 10:44:51: InstallInitialize.
MSI (s) (00:A8): BeginTransaction: Locking Server
MSI (s) (00:A8): Server not locked: locking for product {BAA0DA0F-445F-4C55-9900-0EC9D15CCFCF}
Action 10:44:51: GenerateScript. Generating script operations for action:
GenerateScript: InstallInitialize
MSI (s) (00:A8): Note: 1: 2205 2: 3: #_PatchCache
MSI (s) (00:A8): Note: 1: 2228 2: 3: #_PatchCache 4: SELECT `PatchId` FROM `#_PatchCache`
MSI (s) (00:A8): Note: 1: 2262 2: Icon 3: -2147287038
Action ended 10:44:51: InstallInitialize. Return value 1.
MSI (s) (00:A8): Doing action: OnMoving
Action start 10:44:51: OnMoving.
GenerateScript: OnMoving
Action ended 10:44:51: OnMoving. Return value 1.
MSI (s) (00:A8): Doing action: OnFeaturesInstalling
Action start 10:44:51: OnFeaturesInstalling.
GenerateScript: OnFeaturesInstalling
Action ended 10:44:52: OnFeaturesInstalling. Return value 1.
MSI (s) (00:A8): Doing action: ISSelfRegisterCosting
Action start 10:44:52: ISSelfRegisterCosting.
MSI (s) (00:A8): Creating MSIHANDLE (111) of type 790542 for thread 2728
1: Beginning Costing Process...
1: Initializing Property Bag...
1: Getting file count from property bag
1: File Count : 0
1: Reading SelfRegItems from table, and perform costing...
1: excooltips.dll
1: MBScroll.ocx
1: scrrun.dll
1: WRMenu.ocx
1: abcMain.dll
1: TopMenu.ocx
1: avHyperLink.ocx
1: abcLiveLink.dll
1: SPO.dll
1: Comitting Property Bag...
1: Begin Comitting Property Bag
1: Write KeyList count
1: Finished Comitting Property Bag
1: Finished Costing Process...
1: Setting Costing Info Location ISSelfRegisterFiles : D:\Profiles\mstrat\LOCALS~1\Temp\~F9.tmp
1: Setting Costing Info Location ISUnSelfRegisterFiles : D:\Profiles\mstrat\LOCALS~1\Temp\~F9.tmp
1: Setting Costing Info Location ISSelfRegisterFinalize : D:\Profiles\mstrat\LOCALS~1\Temp\~F9.tmp
Action ended 10:44:52: ISSelfRegisterCosting. Return value 1.
MSI (s) (00:A8): Doing action: ISUnSelfRegisterFiles
Action start 10:44:52: ISUnSelfRegisterFiles.
Gene
Uninstallation, unregisters mshtml.dll!
AndrewG
, Dec 12 2005 13:58
Posted 13 December 2005 - 12:58
Try to find out the registration information of mshtml (like the ClassId). Then look for it in the log, and also in your built .msi file (not just in your InstallShield project).
Posted 13 December 2005 - 14:41
Stefan
thanks very much for the response. I located the ClsID on the build machine by using the 3rd party utility Regctrls. I then searched for this ClsID in the following:
1. The verbose log created during installation by Installshield
2. The verbose log created during uninstallation by Installshield.
3. The log created by RegMon, with a filter set on IDriver.exe, during installation.
4. The log created by RegMon, with a fillter set on IDriver.exe, during uninstallation.
The ClsID does not appear in any of the log files
Any further suggestions would be appreciated.
Andrew
Andrew
