I have craeted a small patch(Say patch 5) using InstallShield X Patch design view which should update main release or release+patch 4.
I had created patch 4 using InstallShield QuickPatch previously.
Now because of some reason, I can update my main release using patch 5, but If I try to update {release+patch 4}, It doesn't update any files.
I have run validation which doen't give any error.
Any help will be appreciated.
Logfile for Update of {release+patch 4} is attached here.
-ViPuL
Patching problem
vnadoda
, Sep 16 2004 23:01
Posted 17 September 2004 - 13:30
No attachment (please ZIP your log file to make sure it#s less than 100 KB)
Look out for SELMGR messages in the log.
Posted 17 September 2004 - 15:00
Thanks for quick response.
I couln't find any instance of SELMGR.
Logfile zip is attached herewith.
-ViPuL
-ViPuL
Posted 17 September 2004 - 18:03
It looks like the REINSTALL property isn't set. As a result none of the files gets reinstalled (all action requests are null). As a test perform a repair after you installed the patch. this should actually update the files.
BTW this is the worst case of ***Log Line Misssing*** I've ever seen. Is this an extremely slow machine?
Posted 17 September 2004 - 19:29
Stefan,
I have set following command line in Patch property "MSI CommandLine Args":
REINSTALLMODE=omus REINSTALL=ALL
but still I can't get it work.
Some how update.exe doesn't seem to set this property properly:-(
any further ideas?
And my build machine is very fast(Dual processor, 1 gig ram). I was also wondering about "Missing Log line" instances!
Thanks a lot.
-ViPuL
any further ideas?
Thanks a lot.
-ViPuL
