I'm using Installshield 2010 and want to change an included msi setup from nested to chained msi.
I'm facing an error 1920 while doing the chained msi saying: 'Error 1920. Service xy failed to start. Verify that you have sufficient privileges to start system services.'
This happens in Vista and Win7 but in XP it works fine.
What can I do to get the necessary privileges for the chained msi that it's possible to start the service inside it.
I can't change the chained msi because we are getting it from an extern partner as is.
Hope someone knows a solution or a work around.
Thanks in advance.
Tom
chained msi - error 1920 by starting service
Thomas B
, Nov 24 2009 14:03
Posted 24 November 2009 - 15:48
Think: in security terms, what's the biggest difference between Vista/Windows 7 and XP?
Edited by VBScab, 24 November 2009 - 15:49.
