Hi, I'm having a problem with MSI Installshield X Express when add in VBScript in Custom Actions to copy a folder by looking for its execution path. The build went smoothly but when I install it, it gives me an error 1720. Below is my vbscript, please help.
Option Explicit
Dim fso, SourceFolder, DestinationFolder, sSourceFolder
Set fso = CreateObject("Scripting.FileSystemObject")
DestinationFolder = "C:\LINKMED\"
SourceFolder = fso.GetAbsolutePathName("Config\")
WScript.echo DestinationFolder
'Call fso.CopyFolder(SourceFolder, DestinationFolder)
Set fso = Nothing
MSI Error 1720 Installshield X Express
KevinLam215
, Sep 23 2005 22:55
Posted 24 September 2005 - 01:25
I think that fso.GetAbsolutePathName() fails, the param does not look like a valid path.
Further you didn't declare nor initialize the WScript variable. WScript.exe and CScript.exe do have an implicit WScript object, but other Windows Installer does not.
Posted 26 September 2005 - 14:30
This script runs just fine manually. However, when I embeded into my MSI package it doesn't work at all. Any idea how to fix this problem? Thanks a great deal for your help.
Posted 26 September 2005 - 16:04
Get rid of of the WScript object, because that only exists when you run a script using WScript.exe or CScript.exe
When you want to run VB-Script code in different environments, like Excel, IIS, and Windows Installer, the object is unknown and you get a scripting run-time error.
