is there a way to locate a file based on the information that is stored in the services listing of windows?
say i have the file services1.exe in the windows services can i find its location of say C:\program files\services1.exe???
locate a file from the services
anf
, Jun 20 2007 09:19
Posted 27 June 2007 - 13:52
In case that you mean a real Windows Service(and not a windows process - got a bit confused because you mention a service with its extension)... you can loop through the key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ where the Service Control Manager stores all the installed Windows Services.
When you find a match, there should be a data::value-pair that gives the path to the service exe(dll?).
