I have a privious product A which include a nested products B.
In order to upgrade A with C,I add the upgrade code of A to the upgrade table of C.When I uninstall A,B was also uninstalled.But after uninstall B,there is a reboot needed.Otherwise,product D nested in the C,which also the new version of B,can not be installed.
How can I install the product D?
Thanks a lot.
The product nested installed can not reinstall.
BrightIdeal
, Oct 16 2003 14:30
Posted 16 October 2003 - 19:18
this sets the value of the path to setup.exe to wherever it is launched from:
NUMBER nvSize, nResponse;
STRING svName;
begin
//Find the path to setup.exe
nvSize = 256;
nResponse = MsiGetProperty (ISMSI_HANDLE, "SETUPEXEDIR", svName, nvSize);
gszSetupPath = svName;
once this value is found and you need to reboot, you can require a reboot. I would recommend creating a temporary registry key that your install checks for here. Add a shortcut to setup.exe in the startup folder and when the setup resumes, it can decide what to do based on the registry key you create before reboot.
STRING svName;
begin
nvSize = 256;
Posted 20 October 2003 - 07:03
Thank you very much.
I think it's a good solution.
But I was confused that when I will reboot the machine?
