If i run my app.msi in comandline my program updates perfect
msiexec.exe /i app.msi REINSTALLMODE=vomus
But if i run the application from the window, appears a messagebox showing the there is installed a version of this product.
In release properties, there is MSI Command Line Arguments. I write REINSTALLMODE=vomus, but this doesn't run ok.
How should I configure this?
Arguments in Basic MSI
NYAKO
, Oct 01 2003 10:40
Posted 01 October 2003 - 18:57
The msi command line arguments in release view are only effective if you launch your setup via setup.exe but not by double clicking the msi file.
Posted 02 October 2003 - 09:12
OK.
How Can I update my program clicking my app.msi ?
If I try to generate a minor upgrade, but it needs a setup.exe, and i want a app.msi
If i generate a new .msi with the changes, when starts the installation appears a messagebox: "Another version of this product is already installed."
I try to change de package code too, but i get the same result
Thanks.
Thanks.
Edited by NYAKO, 02 October 2003 - 09:27.
Posted 02 October 2003 - 09:22
You will have to pass in the command line arguments via msiexec.exe in this case.
The alternative would be to create a patch (.msp).
It's not possible to perfom a Minor Update by simply clicking on the .msi file. This only works for Major Upgrades (where the ProductCode changes)
