Error 1722: There is a problem with this Windows Installer package. A program runas part of the setup did not finish as expected. Contact ....
btw: After deinstalling ISD7 the MSI 2.0 engine is still there. Is this the problem?
Posted 06 December 2001 - 14:32
Posted 20 December 2001 - 20:16
Probably not the best answer but the errors went away
Krut
Posted 02 January 2002 - 18:29
Some Windows 2000 Professional machines are reporting this error near the end of the "generating scripts..." part of the execute sequence.
I found a machine in the shop that showed the same fault. It was one that was upgraded from '98SE to Win2kPro. So I FDISK the machine and installed 2k straight away and I didn't see the error. So it's probably not hardware.
Can anyone suggest what makes some machines complain and not others?
TIA
Posted 04 January 2002 - 19:59
Could you please send the url where you found documents that explains about reverting back to MSI 1.2 engine?
Thanks in advance.
Posted 17 July 2002 - 14:35
Posted 29 July 2002 - 12:33
Posted 26 August 2002 - 14:54
Posted 28 August 2002 - 09:54
| Quote |
| Action ended 19:26:49: InstallFinalize. Return value 1. MSI © (D7:B3): Skipping action: Install2KScripting (condition is false) MSI © (D7:B3): Doing action: Install9XScripting Action start 19:26:49: Install9XScripting. MSI © (D7:B3): Note: 1: 1722 2: Install9XScripting 3: C:\WINDOWS\TEMP\MSIA315.TMP 4: /q:a /r:n MSI © (D7:B3): Product: RM Starting Graph -- Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action Install9XScripting, location: C:\WINDOWS\TEMP\MSIA315.TMP, command: /q:a /r:n Action ended 19:26:52: Install9XScripting. Return value 3. |
Posted 30 August 2002 - 15:49
Posted 02 October 2002 - 11:19
