I have added the msxml4 mergemodule to my setup project. The install works fine for everything but XP. I read in another posting that XP already has msxml4, but when I do a search, I don't find any of the msxml4 files. I get the 2762 error during runtime. If I disable the installation of the merge module, then my install works fine. There seems to be something I am missing here.
Anyone have any ideas? I can install the msxml4 using the msxml.msi that Microsoft has on XP, but I don't want to go that route when we install our product we need to use the merge module.
Anyone?
thanks in advance,
-daren kobata
Installing MSXML4 problem using merge module on XP
darenko
, May 02 2002 16:54
Posted 02 May 2002 - 19:50
Nevermind, I found the problem. Apparently you can't use the msxml4 merge module if you are using the ISWI 2.01 version, or any other version than the 7.02 version. Or a greater version than 7.0. Apparently Microsoft does something to the merge module that is not supported in the older releases.
[b]darenko[b][br][i]darenko[i][br][b]installer[b][br]
