Hello! I am using Installshield Professional for Windows Installer to make a installation package which contains some COM+ applications. (msi format files exported by Component Services administrative tool). I add all the COM+ components to complus table. When runtime, the installer raise error 1928 when register COM+ apllications.
Could you help me to solve this problem? Thank you every much!
Error 1928 when register COM+ Application
Jiang Yong
, Jun 29 2001 03:00
Posted 23 July 2001 - 22:32
I get this error. I have a windows 2000 workstation and msiinstaller works fine after I install VB, Oracle client, ESRI map objects, delphi, this this error happens as soon as I install Seagate Software crystal 8. The application log shows ms DTC service is started even though it is manual, right after crystal 8 installs. Hope you find something.
