Hi there!
I'm using InstallShield 2012 Spring and changed all network path variables to UNC paths in our basic MSI project (to avoid drive mappings on our build server). Now patch creation fails:
PERF INFO: File info Lookup Time: 22 ms
PERF INFO: \\server8\data\Distrib\1.01\setup.msi 87177 ms
PERF INFO: \\server8\data\Distrib\1.02\setup.msi 87184 ms
ERROR: Cannot copy file from '\\?\\\server8\data\Distrib\1.02\setup.msi' to '\\?\C:\Users\muster\AppData\Local\Temp\ISP2D34.tmp\Sta_16000.MSI'.
ERROR: The Last Error Received is: 0x7b (123)
The paths with the '?' look strange. Btw: Setup creation computes without any problems.
After terminating the patch creation process, deletion of the temp folder failes too:
PERF INFO: Time spent generating the patch transform: 0 ms
INFO: Temporary folder is about to be cleaned out and deleted: C:\Users\muster\AppData\Local\Temp\ISP2D34.tmp
ERROR: Internal PatchWiz Error occurred.
ERROR: The Last Error Received is: 0x91 (145)
ERROR: During cleanup, could not delete the temporary folder: C:\Users\muster\AppData\Local\Temp\ISP2D34.tmp.
Any ideas?
Greetings
Meg
