Hi there.
I want to use ScheduleReboot(Reboot Yes No dialog) action 2 times. Already I am using ScheduleReboot action at the end of installation.
Using InstallShield editor, I am not able to add again ScheduleReboot action. I am able to add ForceReboot action.
Even I tried to add ScheduleReboot action using Notepad++ editor then I was not able to open ISM file in InstallShield also.
What I want is that user will see "Reboot Yes/No" dialog box then whenever next time system gets rebooted(Yes/no both scenarios) then Installer should start from next action (action after ScheduleReboot action).
It is urgent and I am new to InstallShield.
Thanks so much. Regards.
Pankaj
Urgent:Want to use ScheduleReboot action two times
goyalpk@yahoo.com
, Jun 24 2011 23:41
Posted 05 July 2011 - 09:35
ScheduleReboot is for reboots at the end of your installation. If you need to reboot in the middle (i.e. continue after the reboot) use ForceReboot instead.
