Hello all,
As I am new to this technology, i need help from you guys.
I am having the problem with [WindowsVolume] folder.
The scenerio is like this,
I am trying to create an MSI, which will just install 4 services.
While repackaging i have taken the 1st snapshot and then I installed the services by running the batch file.
And I manually dumped some folders and files into one drive.(Assume C:\).
After taking 2nd snapshot and repackaging it has created one WindowsVolume folder.
The problem is when i run the msi its installing the services AND it's dumping the windows volume folder into C by default. BUT the problem is if I selected Installation directory to some other drive say D, it still dumping the folder into C drive, but i Want that to be in D drive.
How can it to be done?
Please give some solutions.
Thanks in advance.
problem with Windows Volume folder
avherur
, Sep 11 2008 07:39
