Hi
Can any one solve this problem....
I am generating single exe for BASIC MSI for upgrade old version setupe.exe
with network image and compressed
But I not able to doing that, I am getting problem
like this
another version application already installed ...
use add/remove programs uninstall and installl
can any one tell how to add
reinstallmode = vmous reinstall = all
we can do in setup.ini file , if i do unceompressedstyle
but I want compressed type
thanks
basic msi project with single exe
prabhakar26
, Aug 02 2005 14:44
Posted 03 August 2005 - 13:36
Did you set up your Upgrade table?
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 03 August 2005 - 20:04
In newer versions of InstallShield the setup.exe should set these parameters automatically.
Take a look at your releases view. In the Release or Product Configuration property sheet there may be an option to set REINSTALLMODE etc for setup.ini.
Depending on your InstallShield version you may also be able to use the tool "Modify Setup.ini Inside Setup.exe or Update.exe" at http://www.installsi.../en/msi/isd.htm
