the problem i am having is when i run my install application on an XP or 2000 Server machine, whoever "installs" the application is the only one who has rights to use the newly installed application. (ie: if logged in as Admin and they run my installer, then they are the only one who has rights to use the app.)
What do i need to do so that when the installer is run regardless of who installs it, whoever is logged in on those machines can use the newly installed application?
i was previously using IS ver. 6.2 and i just upgraded to IS ver. 6.31.
Thanks for the help,
KevSev
Installed App Rights on 2000 Server/XP
KevSev
, Oct 11 2002 15:55
Posted 11 October 2002 - 23:35
Is it that your simply creating your shortcuts for the login user instead of all users? 'cause you'll need to call ProgDefGroupType(COMMON); to get the latter.
Although I see from your follow up post you've already figured this out.
