Hi all,
I have a dialod with two fields, in which a user should type an user name and password. I have a custom action to verify this information. If it is not correct I want to give a user the possibility to reenter this information. I want to pops up some message like "Your information is incorrect, please reenter it" . I mean I want to stay in this dialog until the user enter correct information. How can I do that? Any suggestions would be great appreciate. Thanks,
Verify input information
Irina
, Aug 29 2001 15:35
Posted 29 August 2001 - 16:11
Your next button will have events like
DoAction Validate 1
SpawnDialog AdviseUser ValidateResult<>"GOOD"
EndDialog Exit MyAbort
DoAction Validate 1
Your Dialog AdviseUser will have a close/OK/whatever button with the event
EndDialog Return 1
And an optional abort/cancel button with events
[MyAbort] "YES" 1
EndDialog Return 1
It is not possible to exit the install directly from a nested dialog so It is necessary to create a property to indicate that is what you intended.
I do not normally bother with an abort, The user can cancel from the original dialog after dismissing the error informaion dialog if that is what he or she wishes.
Posted 29 August 2001 - 21:52
Thanks, Ian.
I have done something similar. I have set a new property VALIDATERESULT as "GOOD" if it's fine, or 'BAD" othewise in my custom action which verify user information. I have created VBScript custom action to show an error message with button OK conditionaly of this property. Now user can't continue until he enters right information.
