I noticed when I look with Orca that InstallShield 12 seems to drop all empty MSI tables when building a project. Unfortunately, this causes problems when I try to apply a QuickPatch I have from earlier versions of my application. The PatchPackages table in particular has to be present to avoid an installer error.
I found that there is a bug listing for this with MSI Database projects, but the same problem seems to apply for Basic MSI projects.
BUG: Tables Are Missing from New MSI Database Projects
Does anybody know if there is a way to ensure that either a particular table or all the tables that are visible in the Direct Editor get included in the final MSI, even if they are empty? The workaround listed in the bug report doesn't seem to work like they say, or at least not for Basic MSI projects.
Empty MSI tables getting dropped in IS12
ds1068nm
, Jun 04 2007 04:01
Posted 04 June 2007 - 11:04
| InstallShield 12 seems to drop all empty MSI tables when building a project |
Yes, that's true. There's an xml configuraton file that you can edit to avoid this, see
http://community.mac...ad.php?t=161797
Posted 04 June 2007 - 21:26
Stefan,
Your suggestion worked perfectly. I added a line to the settings.xml file like this:
<PatchPackage MSI="Keep" MSM="Keep" />
Now when I build my projects, there is an empty PatchPackage table there and that allows the QuickPatch I have to install correctly, without the error 1305 I was getting.
Thank you so much for your help!
