Is it possible to change the NTFS permssion on a folder that is installed by my MSI? Within IS Developer I see that you can modify a file attribute, but I don't see where you can modify a folder attibute. Basically, I have an Access DB and it will create a *.ldb file. The package works fine as an Administrator but when I try to run the app as a limited user, it fails. The reason is that the folder NTFS permissons has only Read, Read & Execute, and List. Thanks for any help with this.
Change NTFS Permissions?
djrickp
, Jun 27 2003 17:18
Posted 30 June 2003 - 19:52
You can set directory permissions in the Component view (as a property of the component that's installing to this directory)
