One component of my application uses MSADO15.dll. I tried to register this file on windows server 2003 through self extratction but failed. Then through bat file but no success, then I tried to merge registry file. Entries are added successfully until the setup finishes. Once setup finishes all the entries automatically deleted by windows and I am unable to register msado15.dll on Windows Server 2003 by any means.
On XP machine it is working fine.
Please help
Rz Nain
MSADO15 Registration Issue
rznain
, Mar 11 2010 09:16
Posted 11 March 2010 - 10:53
Isn't this part of the MDAC package? Are you sure you can redistribute the MSADO15.dll alone?
Posted 15 March 2010 - 12:36
Yeah this is the part of MDAC but the issue is related to registration. If I register this manually then it works for my application, I prepare a fresh machine with 2003 Server installation and then install my app there. The particular module shows runtime errors. However, when I registered this DLL manually, my module starts working.
I don't know what to do now.
