Hi Dudes,
I am relatively new to the installshield world, so my apologies incase many of u studs find my problem age old n poor. :-)
I am facing the problem wherein I append the softwares path to the PATH env variable but after the uninstall the software PATH does not get removed from the path env variable.
For that I am using the code given on
http://www.installsi...s/en/isp_os.htm
topic to look for :: Handle Path Environment on NT
The author gives implementation of the two function SetEnvPath() and RemoveFromPath().
I fail to understand from where should I call RemoveFromPath() such that it will be executed during uninstall.
Any suggesstions... Please help !
Else is there any better way , I want to avoid useing a DLL for uninstall, if possible.
Thx so much,
Cheers
Sandeep !
Path Problem With Installshield
sandeep
, Feb 11 2004 17:36
Posted 11 February 2004 - 18:19
Why don't yu use the method that is built into MSI, i.e. the Environment table?
