I am using MTSAdmin.Catalog object for installing COM+ components through a custom action.Is there any property to set the Security level of the package in the Security tab of the packages to the process level.By default the second button that is Enforce component level access check is selected.
This are the package properties I am setting through the script.
try
set catalog = CreateObject("MTSAdmin.Catalog.1");
set ObjMachineProperty = catalog.GetCollection("LocalComputer");
ObjMachineProperty.Populate;
set packages = catalog.GetCollection("Packages");
packages.Populate;
set newPack = packages.Add;
newPack.Value("Name") = "Example";
newPack.Value("SecurityEnabled") = "N";
newPack.Value("RunForever") = "Y";
newPack.Value("Authentication") = 1;
packages.SaveChanges ;
catch
endcatch;
Is there any property to set the Security tabs Security level first option so that there is access checks only at the application or the process level.
Any help is highly appreciated.
Thanks and Regards,
Jagat
Is there a way for setting process level security
jagat
, Jul 05 2002 13:05
Posted 08 July 2002 - 15:35
Hi Leigh,
Thanks for your suggestion
can you please specify as how to use the property "AccessChecksLevel".
I tried to check the package property through
newPack.Value("AccessChecksLevel") = 0;
But the Caustom action would abort at this point without installing the package.
Am I doing something wrong or need to initialize some other properties before using it.
Regards,
Jagat
Regards,
Jagat
jagat
Software Engineer
http://www.icode.com
Software Engineer
Posted 11 July 2002 - 07:06
I had to use COMAdmin.COMAdminCatalog to set the property for OS > Win 2000.
Here is the sample code..
if (GetOS() > Win 2000) then
try
set catalogCOM = CreateObject("COMAdmin.COMAdminCatalog.1");
set PackageCOM = catalogCOM.GetCollection("Applications");
PackageCOM.Populate;
n = PackageCOM.Count;
for i = (n - 1) downto 0
if PackageCOM.Item(i).Value("Name") = szPackageNAme then
PackageCOM.Item(i).Value("AccessChecksLevel") = 0;
PackageCOM.SaveChanges;
i=0;
endif;
endfor;
catch
endcatch;
endif;
HTH someone.
Regards,
try
i=0;
endif;
endfor;
catch
endcatch;
endif;
HTH someone.
Regards,
jagat
Software Engineer
Software Engineer
