Hi, I have an Installshield project which can install different flavors of a product based on the entered serial number. I want to give each flavor its own product code. I tried to use the MsiSetProperty() method to do this. The method returns success but the product is installed using the product code specified in "General Information|ProductProperties". Can any one guide me why it is not working. Thanks.
Changing ProductCode at runtime
rahmed
, Nov 07 2005 21:15
Posted 07 November 2005 - 21:15
retCode = MsiSetProperty(ISMSI_HANDLE,"ProductCode", "{979D84E8-BA46-4653-89F2-C2CD73997344}"); if (ERROR_SUCCESS != retCode) then Sprintf(message, "Failed - Error = %d", retCode); MessageBox(message, INFORMATION); else Sprintf(message, "Succeeded - Error = %d", retCode); MessageBox(message, INFORMATION); endif; |
Posted 08 November 2005 - 11:46
No offence, but this sounds like a very dodgy approach. The product code is a very integral part of an MSI setup. I am not sure you can change the product code on the fly after the setup has launched. You may be able to change the product code by applying a different transform file to the same base MSI. It would probably be best to run this logic in a custom setup.exe that would then call the MSI with the appropriate MST file to install the correct flavor of the product.
Posted 09 November 2005 - 20:46
OK, I'll go with the transform approach then. However I tried it and it does not seem to work correctly. If I install the product using a transform that changes the product code and then retry with a new transform that also changes the product code, it works correctly. But if I install the product without a transform and then install the product using a transform that changes the product code, in that case it brings up the maintenance dialog. Can some one tell me why is this happening. I checked MSDN pages and according to it, this should work just like the first scenario. I am using Installshield 10.5 generated InstallScript MSI project.
Thanks.
Thanks.
