hi,
How to remove the read only attributes of a folder/file which is installed by dynamic file linking?
Regards,
Vishalv
Unable to delete virtual directory
vishalv
, Aug 18 2005 16:24
Posted 18 August 2005 - 18:14
Try this...
| // Files copied from SETUPEXEDIR have their attributes set to // read-only. These files must be modified to clear the read-only // attribute. // Get the first *.mmm file svDir = INSTALLDIR + "Data\\"; svFileSpec = "*.mmm"; nvResult = FindAllFiles (svDir, svFileSpec, svMatchingFileName, RESET); while(nvResult = 0) // Clear the file's attributes. SetFileInfo (svMatchingFileName, FILE_ATTRIBUTE, FILE_ATTR_NORMAL, ""); // Find the next matching file name. nvResult = FindAllFiles(svDir, svFileSpec, svMatchingFileName, CONTINUE); endwhile; |
Posted 23 August 2005 - 11:25
Thanks a lot for the code snippet. This piece of code works like a charm.
I have another query.
I am unable to change a virtual directory on upgrading my installation.
The problem is that after upgrade, the virtual directory should point to a different folder.
I have tried to delete the virtual directory through some VC++ code, before the file copy for the upgrade happens.But this is not successful.
Any light in this matter will be extremely helpful.
Regards,
Vishal
Regards,
Vishal
