can anyone add insight here? i assume it works because the session still exists while the script is getting executed, so what kind of circumstance would lead to the session not existing?
deferred custom action and public props
CM XS
, Aug 22 2001 21:03
Posted 22 August 2001 - 21:03
I know you're only supposed to access properties from a deferred custom action using only CustomActionData. But i have tried accessing public properties using MsiGetProperty(...) and it works.
Posted 23 August 2001 - 00:05
Which version of Installshield are you using? With Developer 7, Installscript custom actions run under a seperate process, called IDriver.exe (I think). These custom actions have full access to public properties regardless of whether they are running as immediate or deferred.
Posted 23 August 2001 - 17:04
thanks for the response leigh, i'm not using installshield. strictly ORCA and C++. to access these properties i'm using the msi API, calling MsiGetProperty(...).
CM
Posted 29 August 2001 - 06:55
You can get the productCode and UserSID properties in a deferred CA.
For any other properties the documentation is quite clear: don't do it.
Maybe it works sometimes, on some windows versions, with some windows installer versions, for some properties. But it undocumented, so don't use it. Even documented functions are often not 100% reliable, so I wouldN#t rely on anything that the docs say it won't work.
