Hi
I want to create a shortcut on the desktop but only dependant on a variable that gets set by a value entered in a dialog.
Can it be created on the fly ie if the customer enters an ID of KC then the shortcut is created but if teh customer ID is DT then its not???
Michelle
Creating Shortcuts dependant on a variable
Chelley
, Sep 21 2004 16:41
Posted 22 September 2004 - 10:25
The easiest way to create a shortcut conditionally would probably using the AddFolderIcon function in an if statement.
