Hi, Can anyone help? During an install of an application I need to force the user to change the subcomponent(s) of a main componant before proceeding to the next stage of the install. Can this be done?
Force Selection of Sub component(s)?
JamesH
, May 21 2001 09:30
Posted 21 May 2001 - 09:53
Hi James,
You can use ComponentIsItemSelected to check the status of (sub-)Components, and ComponentSelectItem to (de-)select (sub-)components.
To use them is this case:
- Check which subcomponents are selected, and which not.
- After the user clicks 'Next', check if the subcomponents have been changed. If not, Pop a messagebox and show the screen again.
Ide
