LaunchAppAndWait is not invoking wscript is not invoking wscript properly in XP machine. My developer machine its invoking wscript.exe proerly. But in some other machines its not doing so!!
LaunchAppAndWait
anoopov
, Apr 19 2004 13:14
Posted 19 April 2004 - 14:46
I'm not 100% sure on this, but I believe that if the default scripting is not set to wscript, it will not run. There is the choice of setting the default between Windows scripting and "C"scripting. So if "C" is set as default, WScript might not work.
I believe you have to first do a LaunchAppandWait for:
wscript.exe /H:WScript
There might be a way to explicetly call the WScript host, but I forget how to do that.
Like I said, this is just the first thing that came to mind... but I may be completely off.
Good Luck
Nick
Good Luck
Nick
