Hi there,
what i am trying is to do as MSN does, lanuching myapp.exe after myapp installation.
I can lanuch notepad.exe, but i can't launch myapp itself.
Who can guide me through? pls detail steps and settings. because i already tried any settings before.
Thanks.
spj
, Aug 28 2003 18:12
Posted 01 September 2003 - 23:23
You will need to create a custom action that will run an executable installed with your product. You can reference the [destiation] that insatlled the executable to.
Posted 26 September 2003 - 05:02
You might do well to use the "Launch Executable" custom action type rather than running an Installscript with LaunchApp / LaunchAppAndWait.
I tried to make an application launch at the end of the setup for quite a while using Installscript and it never worked. When I switched to the "Launch Exectuable" action it worked right away.
Posted 02 October 2003 - 04:30
I suspect the reason Installscript custom actions don't work from the "setup complete" dialog is because the Installscript engine is no longer running.
