Im creating a checkbox control in a custom dialog, however, during setup I cannot see the checkbox until I click on the space where it suppose to be.
How can I make it so users can always see it? Note: the checkbox is not suppose to be hidden
Checkbox in MSI
mouy
, May 18 2004 23:52
Posted 19 May 2004 - 02:45
There is probably another control covering the check box. Try moving the control to check if this is the case.
Posted 19 May 2004 - 08:14
If this is a dialog with a white background (i.e. a white bitmap as background) make sure that background bitmap control has the tab stop bit set (!)
