How can I run my custom action after SetupProgress dialog was closed and before SetupCompleteSucces appears.In my custom action I run other install.
I want show -> SetupProgress (Copy files) close it -> Run Custom Action (other Install) -> show SetupCompleteSucces
When SetupProgress Dialog is disappears?
Kiril
, Jun 07 2001 14:01
Posted 08 June 2001 - 19:51
The custom action wizard allows you to "launch another msi package". Is there a reaon you can't use this?
Posted 12 June 2001 - 01:04
I am facing a similar quandary. I need to chain another, third-party, installer from my installer. However this needs to occur only if the user selects the appropriate feature to be installed.
Ideally the user will do the following:
1. Choose Custom-Setup
2. Select the desired modules (including the pertinent module for this question)
3. Press Next
---The installer should now proceed with the installation process, costing, copying, etc. At the end of this process the installer should launch a custom action that triggers the .exe for the third-party installer.
Any ideas/suggestions are appreciated!
Zach Miller-Catlin
Release Engineer
Posted 14 June 2001 - 10:57
Ok I understand what you mean.
But I want launch my custom action between SetupProgress and FinishCompite dialogs.
I don't want see any dialog behind my third-party installation.
