Hello and thank you in advance for any replies. I would like to make my setup program launch the application at the end of the installation. I'm using the normal Visual Studio interface, not InstallShield or Wise or anything else. Just Visual Studio.
Okay code slueths do that voodoo that you do so well :).
I want my installer to launch the program after installing
seier
, Jan 18 2002 05:37
Posted 18 January 2002 - 22:38
You would do this with a custom action that launches an executable. Unfortunately the VSI development environment doesn't support this. But you can open your finished .msi with Orca and add the required table entries manually.
Posted 26 January 2002 - 03:45
Hi Stefan,
I've opened up an MSI in Orca and it's like seeing the registry for the first time in Windows: daunting. What is the specific section that I would add the program I'd like to launch? Do I enter the value as a string with quotes or without?
Thanks for all your help you rock,
Christian
Christian
Posted 26 January 2002 - 22:53
The CustomAction table plus a few more. You will have to dig into the MSI documentation if you want to do this on the low level of a table editor like Orca.
Or you buy a more pwoerful authoring tool that can set this up with point and click.
Posted 27 January 2002 - 04:15
Thanks Stefan,
I believe I found the informaton I needed. I'll have to try it later, but here's what I found in MSDN for others who might need to do this:
http://msdn.microsof...rary....7i0.asp
