Hi Folks,
I have a large install that I am working on which has many problems. I have tried everything that I know of to enable the MSI log that gets created when an application is installed, but, for some reason, the C:\Temp folder is empty and the only log that I can find is in the logged in users Temp folder, and it only shows any messages that I might have encountered during the install.
Anyone know what I can do here? Any help would be greatly appreciated.
Thanks in advance,
Mike
DevStudio 9: Install Logging
mpento
, Dec 15 2005 15:28
Posted 29 December 2005 - 15:54
Have u tried:
Msiexec /i <PACKAGE.MSI> /L*v
or
run --> gpedit.msc
Local Computer Policy --> Administrative Templates --> Windows Installer --> Logging
Set the policy enabled, with necessary params.
run --> gpupdate /force
or
use http://www.sysintern.../DebugView.html
note that u need to enable a DWORD DEBUG=0 in HKLM\Software\Policies\Microsoft\Windows\Installer
Hope this helps.
Oh yeah.. always watch the eventlog.
or
run --> gpedit.msc
or
Hope this helps.
Posted 29 December 2005 - 17:50
Hi Frank,
I can log from the command line with msiexec.exe just fine, I have not looked into the second suggestion though for the policy setting and that could very well be the problem. I have used debugview before to monitor messages from my install script functions using kernel32.dll but did not know about this other setting. That is super-useful information, thanks!!!
Mike
Mike
