I am running 2.03 of ISWI and I set my components for the ocx's and dll's to extract at build. I install my software and it works fine looking at a directory called common files\vision shared. When I remove the application, I get an unstable active X error when going back into installshield and explorer 5.5. The files are deleted in my directory. The original files that are in the system directory are still there. I though you are able to load your dll's and stuff in another directory other than the system. Has anyone tried this before and does it work for you.
registry problem
laddison
, Apr 13 2001 20:47
