Regards,
Thomas Eskesen
Product Name
Posted 08 May 2001 - 15:43
Posted 08 May 2001 - 21:00
HOWTO: Changing the Uninstall Name Displayed in the Add/Remove Programs Applet
InstallShield for Windows Installer uses the Product Name for the uninstall name. To change the Product Name, do the following:
Click on the Product Properties node in the Project tree.
Change the Product Name in the property sheet.
Posted 09 May 2001 - 07:23
BUT I would like to set the name using e.g. MsiSetProperty(hMSI,"ProductName", "Fido");
Using this I can set the Productname in the captionbar etc. - but NOT in the Add/Remove Window!??!??!?!
I'm using release flags to generate different installation programs for different (similar) programs - with different names!
Regards,
Thomas
Posted 09 May 2001 - 08:05
Set m_ISWiProject = CreateObject("ISWiAutomation.ISWiProject")
strFile = "D:\DEVELOP\WISETUP\\FIDO.ism"
m_ISWiProject.OpenProject strFile
m_ISWiProject.ProductName = "This works"
Regards,
Thomas
Posted 09 May 2001 - 08:50
Posted 09 May 2001 - 09:35
Where can I wirte the Alternate name?
How do I then use it?
Regards a gratefull,
Thomas Eskesen
Posted 09 May 2001 - 11:56
Posted 09 May 2001 - 13:26
Go to (6) Prepare for Distribution
Click Releases
Select the Product Configuration you want to modify
Enter the Product Name on the right panel.
You can have several product configurations, each with a different product name, product code, and configuration flags (to include/exclude features from the build)
This requires IPWI 2.x, not available in ISWI 1.x
Posted 25 July 2001 - 10:26
( I would like to do that because my ProductName is "versioned" and i read the version in a .h file when i build the setup. So i can't specify Name in the IDE)
Posted 26 July 2001 - 09:53
I overwrite with a Deffered CA the Registry key
"HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{ProductCode}\DisplayName" and it works good.
hope that helps.
