is there a way of detecting whether or not the user has spawned a silent install (msi) within installscript or a custom action?
does anyone know? all i need is to detect whether a silent install has kicked off and if it has, then i'll set a flag of some sort. has anyone ever done this before?
detecting a silent installation
tl0
, Jan 10 2003 20:56
Posted 13 January 2003 - 13:52
there is a UILevel property that you can use to determine, or set. it has four ( 4 ) levels to indicate none, basic, reduced, or full.
Posted 24 January 2003 - 08:26
The scripts creating the Sd* dialogs contain the following code snippet:
if (MODE = SILENTMODE) then
endif;
Maybe that's what you need?
You can find those scripts in c:\program files\installshield\developer\script\isrt\src
endif;
