Some files are not being updated with an upgrade
erich
, Aug 09 2004 14:33
8 replies to this topic
Posted 09 August 2004 - 14:33
With the latest build of our product we notice that some binary files are being updated but not others. In each case the change in version numbering is the same.
The files that are being updated are in a different part of the 'feature tree' so it is plausible that some property at feature or component level is causing the difference in behaviour, but it's not immediately obvious what!
Posted 09 August 2004 - 17:20
A verbose log file should help to diagnose the problem.
Posted 11 August 2004 - 13:04
I have generated verbose logs for the initial install and the upgrade. All I can see is that in the upgrade for the componet that is updated we have: -
MSI (s) (84:18): Component: DevFC; Installed: Local; Request: Local; Action: Local
Followed by lines related to copying the file checking the version number, etc
For the component that is NOT updated we have: -
MSI (s) (84:18): Component: Epstiff; Installed: Local; Request: Null; Action: Null
What I did notice is that if we look at the feature 'DevFC' belongs to we have a line: -
DeviceControllers; Installed: Local; Request: Reinstall; Action: Reinstall
While for the one that doesn't get updated we have: -
Feature: Core; Installed: Advertise; Request: Reinstall; Action: Reinstall
Now based on this I recreated an 'earlier' install where the Core Feature's 'Advertised' property was set to 'Allow Advertise' (whereas it was actually set to 'Disallow Advertise'). If I now run this on a clean system and then run the new install to do an upgrade the Epstiff compnent IS upgraded.
Of couse this doesn't solve my problem as I can't change already installed systems!
I attach the verbose logs.
Edited by erich, 11 August 2004 - 13:11.
Posted 11 August 2004 - 13:05
Here's the other log!
Edited by erich, 11 August 2004 - 13:10.
Posted 11 August 2004 - 16:36
| Feature: Core; Installed: Advertise; Request: Reinstall; Action: Reinstall |
This typically means that you have broken the compoentn rules. And indeed your update log has a couple of these SELMGR messages that are typically seen in this case:
| MSI © (20:20): SELMGR: ComponentId '{07894B0D-5610-4C09-9B12-9BC36F8BF843}' is registered to feature 'CrystalRedist', but is not present in the Component table. Removal of components from a feature is not supported! MSI © (20:20): SELMGR: Removal of a component from a feature is not supported MSI © (20:20): SELMGR: New components have been added to feature 'AddressBook' MSI © (20:20): SELMGR: Component 'AllOtherFiles' is a new component added to feature 'AddressBook' MSI © (20:20): SELMGR: Component 'Btrout' is registered to feature 'BrooktroutTR1034Controller', but is not present in the FeatureComponents table. Removal of components from a feature is not supported! MSI © (20:20): SELMGR: Removal of a component from a feature is not supported MSI © (20:20): SELMGR: Component 'BFaxInit' is registered to feature 'BrooktroutController', but is not present in the FeatureComponents table. Removal of components from a feature is not supported! MSI © (20:20): SELMGR: Removal of a component from a feature is not supported MSI © (20:20): SELMGR: Component 'INI_Full' is registered to feature 'Core', but is not present in the FeatureComponents table. Removal of components from a feature is not supported! MSI © (20:20): SELMGR: Removal of a component from a feature is not supported |
While adding components is allowed, removing them is not. this includes removing merge modules, or changing component GUIDs.
Posted 11 August 2004 - 18:19
But none of the components we are concerned about has been added or removed - is it possible that removing a component from a feature can cause anothe component not to update properly?
If that is the case can we fix the problem by restoring deleted componets? (i.e. could we recreate components as 'dummy' components which matching names and codes but no files)
Posted 12 August 2004 - 03:45
Try a major upgrade (unless this is what you are already doing).
Posted 12 August 2004 - 17:21
Removing ANY component from the msi package will prevent you from successfully installing a small or minor update.
Posted 13 August 2004 - 14:22
OK, I've modified by new install to 'restore' all such missing components with matching codes.
This seems to update fine now - Many Thanks!!
