I have to run an exe that will will install the drivers for USB device. In the OnInstallFilesActionAfter event I am calling the exe using the code below
BDDriverDirectory = "c:" ^ "USB to Serial Drivers";
nResult = LaunchAppAndWait(BDDriverDirectory ^ "hidcominst.exe","-I " + BDDriverDirectory ^ "hidcominst.inf", WAIT);
It does not install the driver.
I tried the same code in an installscript 11.5 project. It does not work there too.
But on a installscript X project this code works fine and installs the driver. Is this a 11.5 bug. we just upgarded 2 weeks before.
Is this a bug?
Thanx in Advance --B
LaunchAppAndWait Fails in IS/MSI project ver11.5
bijuishere
, Mar 03 2006 21:28
Posted 04 March 2006 - 00:53
I continued to research this and I see that when I call this batchfile using LaunchAppAndWait in OnBegin(), it works just fine. But if I try to call it from any other event it does not. The batch file actully copies files into the C:\winnt\system32\drivers & C:\winnt\system32\inf folders and that is all it does. Is it anything to do with the permissions that the windows installer engine has? Or is it that this installscript function does not work well in an IS/MSI project? Please help.
--B
--B
