Hello,
Let me explain my problem.
I have two windows services the functionality of which is written in java(jar files). To install these services, an executable wrapper is written which accepts a set of command line parameters. These parameters are interally passed to the jar files and the services get installed. This executable wrapper gets registered in the service control manager as the service executable.
I could invoke this executable wrapper using an EXE custom action. However i do not prefer this, so do a lot of windows installer experts on the web.
So i was kind of thinking if i could use the windows installer service tables to accomplish my task. Is this possible?
The service exe is the key file for this component.
I also want to be able to pass command line parameters as i install the service using the service control tables.
For example: a.exe -b -c. a.exe is my service executable and b and c are the arguments.
Questions:
1)Can i make use of service control tables to install my service?
2)Is it possible to pass command line parameters to my service executable, if the service installation requires these parameters?
3)Is this possible for services written in java?
Any help would be very much appreciated
Regards,
Kiran Hegde
Using the windows installer service tables to inst
kirann_hegde
, Oct 14 2010 04:49
Posted 01 November 2010 - 10:19
When creating the serice you can specify start parameters. Is that what you want?
