Hi...
I have created a custom action named reboot which is meant to reboot the PC after installation.
I want to do reboot only when the user do a fresh install or when they do an upgrade(minor/major).
I don't want to reboot when the user do modification or repair (from the Add/Remove Program List).
I have set the condition of the custom action to REMOVE<>"ALL" and NOT MAINTENANCE.
Howeve, it still prompt for reboot when the user finish the modification from maintenance.
I heard that MAINTENANCE can only be used for InstallScript project. Whereas my installer is built using Basic MSI.
Is there any way to do this?
I welcome any suggestion.
Thank you in advanced.
proper condition
agustina_s
, Dec 08 2004 11:02
Posted 08 December 2004 - 17:21
Firstly, do you know that a minor upgrade of a product can be done by reinstalling (repairing) it using REINSTALLMODE=vomus.
So if you want to run the action only when your product is not already installed then use the condition 'Not Installed'.
Kapil
Kapil
Posted 09 December 2004 - 02:38
Hi Kapil
I can't use the condition Not Installed, because it is refering to minor upgrade only. In this case the condition will be false for major upgrade and new installation.
Actually the one that I want is the condition whether it is a maintenance or installation.
In the Add/Remove program list, user can click Change and then they will go to the Maintenance Welcome dialog box.
If they click Modify/Repair, the installer will do some reinstallation. In this case I don't want to reboot the PC.
Posted 09 December 2004 - 05:41
Hi Kapil it works for condition REMOVE<>"ALL" and Not Installed.
Thanks a lot....
Thanks a lot....
