Hello,
I am very new with installShield.
I build an install that need the framework .net.
In the relaese wizard, I the setup dot.NET.
The install begin,
It propose me to install the framework.
My question is quit simple, I want to test if the framework is not yet installed?
so where must I include this test condition.
In the Release wizard there is no option to check if there is a previous version?
Thanks in advance.
detect framework dot NET
pavlacki
, Apr 04 2005 15:14
Posted 04 April 2005 - 19:21
I used the code below in the OnBegin InstallScript to test for the Framework and then test for the service pack. If the Framework is not installed, I abort. If SP1 is not installed, I LaunchAppAndWait the .exe to install it. You may be able to modify it for your use. NOTE: I test for REMOVEALLMODE to make sure that I'm not here doing an uninstall.
svFolder = "Software\\Microsoft\\NET Framework Setup\\NDP\\v1.1.4322";
if REMOVEALLMODE == 0 then
if RegDBKeyExist (svFolder) < 0 then
MessageBoxEx ( "Microsoft .NET v1.1 not installed!", "", SEVERE );
abort;
endif;
RegDBGetKeyValueEx ( svFolder, "SP", nvType, svValue, nvSize );
if ( svValue != "1") then
szTarget = SRCDISK ^ "\\" ^ "NDP1.1sp1-KB867460-X86.exe";
LongPathToQuote(szTarget, TRUE);
LongPathToQuote(szApplication, TRUE);
LaunchAppAndWait (szTarget,"",LAAW_OPTION_WAIT);
endif;
endif;
abort;
endif;
endif;
endif;
