Hello,
i had an error when i used PackageFromTheweb. I am using IS 5.5
The error is :
PACKAGE FOR THE WEB ERROR
This package is used internally by PackageFromTheWeb. It should not be executed directly.
can you help me?
thanks
PackageFromTheWeb
cathy
, Apr 30 2003 15:00
Posted 05 May 2003 - 15:31
What version of pftw do you use?
When do you get that error?
Gruß / regards
Thomas
Thomas
Posted 06 May 2003 - 10:41
hello,
I use PFTW version 2.04 and the message appears when
I copied this file to the WEB server and tried to execute it but ireceived the following message
thanks for your answer
cathy
cathy
Posted 06 May 2003 - 12:28
Does it work if you have the exe locally on your hard disk?
What web server is this? IIS, Apache, ... Which server OS (Windows, Linux, ...). Did you make sure that file execution is disabled for the directory where you post the package? (Else it will try to run on the server)
Posted 09 May 2003 - 11:24
good morning,
We used IIS.
the problem appeared after i copied .Exe
Perheaps a problem of loading ?
I am connected via the Administrator user on server (w2000).
I copied the exe file to the c: and double clicked to execute.
thanks.
cathy
We used IIS.
thanks.
cathy
