C is system disk
E partition space available > 1.0 GB
Installation application need 405 MB
The disk space not enough error shows up
just after welcome dialog
I didn't write any disk space check code
Is it so called installation check ?
how to let the disk space check the target dir not system disk ?
Need some help ..............
disk space check problem.........
goodluck999958
, May 17 2005 04:28
Posted 17 May 2005 - 08:08
You can do this using this code
if (FeatureCompareSizeRequired(MEDIA, svDisk, nvSize) < 0) then ParsePath ( svDisk, TARGETDIR, DISK ); MessageBox ( "There is not enough free space on drive " + svDisk + "." , SEVERE); endif; |
Try to use it right after your folder selection dialog ...
Bonum initium est dimidium facti
Posted 18 May 2005 - 09:01
Thanks for your reply,
but first I need to know how to avoid the disk space not enough error to show up,
it comes before target folder selection dialog,
and can't close it anyway.
How I can avoid the disk space not enough error to show up ??
Posted 18 May 2005 - 10:18
Solved !
There is a FeatureCompareSizeRequired just before target folder selection dialog
just move it after target folder selection dialog
Thanks............
Thanks............
