Hi ,
Currently i am trying to automate the setup creation process for our product, and i want to change the package code for each build through command line , for this i am trying to use the below format which builds the setup through command line.
IsCmdBld.exe -p "Setup.ism" -y "7.11.00" -z Package Code={ABCD2735-DAFA-4E17-A034-98AC37472F65}
Here the product version is updated since its a windows installer property but Package code is not getting updated, because its not a windows installer property.Is there any way i can change this property value through command prompt or can i change this property to windows installer property.
Regards,
Balaji
Not able to change d packagecode frm command line
balaji4u
, Jul 28 2011 05:39
Posted 28 July 2011 - 14:09
If your project is configured to auto-generate PackageCode upon build (which is the default for new projects) I'd expect that the command line builder will automatically generate a new PackageCode for you. Does this not work for you?
Posted 29 July 2011 - 04:40
Hi Stefan,
I will try to enable the property , generate the package code for every build under releases view and check whether it works for my case.
Regards.
Balaji
Regards.
Balaji
Edited by balaji4u, 29 July 2011 - 04:58.
