I have a CA that makes some changes in registry and then launches the application, this CA is placed last in execute sequence, right after InstallFinalize. If I run the installation 'normally', doubleclicking .msi file, everything goes smoothly, I have UI and CA is executed at the end and so on. But I would need to run this installation from command line and in quiet mode, so the cmdline should be something like 'msiexec.exe /i "application.msi" /q' ?
With this /q option my CA is not executed at all, what is the problem?
Some other CAs, which are run in uninstallation, are in execute sequence with condition REMOVE="ALL" and they work fine also in quiet mode...
Thanks in advance
Mikko
