The setup I created can be installed by a dll using slient mode.
Or the user can start the setup normally and make his selection.
The command-line used looks like this
setup.exe /w /s /v"/qn BOARDINSTALL=12"
w to Wait for the install before continuing.
s for silent mode.
v is to pass parameters to the MSI:
qn for no user interface
BOARDINSTALL=12 as a public properties.
If the setup has never been installed, the command-line works perfectly.
But once, the setup has been run, the command-line setup does not behave as I would expect. None of my conditional components are installed.
With the GUI, I have the Welcome Maintenance screen and everything selected gets installed.
Is there a way to force the silent and no-gui install to install the components even if we are in maintenance mode?
Thx
EG
Command-Line parameters
Gig52
, Feb 19 2004 01:47
Posted 19 February 2004 - 19:02
You may need to use ADDLOCAL and REMOVE properties to modify trhe selection state of features. You may also need to set the REINSTALL property. And you must set the msidbComponentAttributesTransitive flag for the component to force a re-evaluation of conditions.
