InstallAware Software Corporation has released InstallAware 5 for Windows Installer – software for building and repackaging installations on Windows, .NET, IIS, and SQL Server platforms. Unique features of InstallAware 5 include high compression, partial web deployment, and a Installer IDE with two-way integrated Visual/Code views. Setups may be defined in state-based fashion using the file, registry, shortcut, and other visual views common to most tools. What’s unique about InstallAware however is the underlying code view. Any time a visual view is used, it updates the underlying code view, which contains a conditionally flowing setup script, complete with language elements such as If and Else directives. The setup script may be directly edited using the script editor, and when switching back to the visual view, the round-tripping IDE keeps the changes in sync. When the setup is built, the output is a pure MSI logo compliant database with no proprietary scripting engine that needs to be pre-installed.
As a special benefit for users of the InstallSite web site InstallAware offers a 30% discount on your whole order when you enter a special coupon code in the order form at http://www.installaware.com/buy.asp
To request the coupon code send e-mail to installaware@autoreply.installsite.net
InstallAware 5 released
, Dec 19 2005 17:41
No replies to this topic
Posted 19 December 2005 - 17:41
