I am creating an Installscript project using Installshield 11 and I need to provide a screen which can display the SQL Server instances installed on a machine. For this I have used the SQLBrowse dialog box. This works fine except when I do not have a default SQL Server instance. The problem that I am facing is that when my machine has only one instance of SQL Server called MyInstance1 then the SQLBrowse dialog box displays 2 instances Local and Local\MyInstance1. The default instance is not existing on my machine still it is displayed. How do I stop this?
Selecting SQL Server Instance
Vaibhav.Goel
, Mar 21 2006 06:33
