I'm trying to read out some environment variables to customize my setup.
This means: If I have the variable 'Installation=TEST' is set the setup should install
the Beta-Files of the Application. If the variable is set to 'Installation=Prod' the
Productive-Files should be installed.
How can I realize it "the best way"?
Environment Variables
zaphod
, May 13 2003 10:16
Posted 13 May 2003 - 16:37
You will want to create a type 51 custom action. This will allow you to set a property to the value of the environment variable. The row in the CustomAction table should look something like this.
Action: GetInstallationValue
Type: 51
Source: INSTALLATION
Target: [%Installation]
Anthony
Type: 51
Anthony
Product Availability Developer
Avantis
Invensys Process Systems
Using InstallShield Developer 7.04 - Basic Project
Avantis
