Hi all,
I have an install template (.ism) that is located in a certain folder, InstallShield 2010 Projects\OurPro. Here, all builds fine.
Now, with our upcoming version, I created a folder as follows...
InstallShield 2010 Projects\2.0\OurPro.
I copied the .ism to this location and attempted to build after changing the Path Variable from the old source location (C:\Install Source\OurPro) to the new source file location (C:\Install Source\2.0\OurPro). Unfortunately, I get can't find/compress messages on the Merge Modules. I tried de/re-selecting the modules in the Redistributables view, but that didn't work.
Now, if I copy the contents of the 2.0 build folder back up a level (original versions build path), everything builds properly.
How can I remap to the Merge Modules I need to include from the \2.0 folder.
Any help greatly appreciated.
Moved .ism now have Merge Module Problems...
Superfreak3
, May 21 2011 14:21
Posted 21 May 2011 - 21:46
I believe I found the problem. The paths I gave were examples and it seems the real path naming pushes me over a length limit.
http://community.fle....d.php?t=184338
This BUG needs to be fixed!!!
